floppy Top shock absorber mount
igaroot
New Registration
Davey Jones Locker
E300D 1996 W210
Passenger side shock absorber does not compress during normal driving. Top of shock absorber pushes up and then back down through the body / wheel well. Washer jingles and body amplifies the sound. My partner thinks the car is gonna explode. Yes, she is a woman.
Is it as simple as a bad shock? Is there a mount on the underside of the body / wheel well that popped off?
oigle
members.optusnet.com.au
You can easily check. Remove the wheel and have a look at both ends of the shocker. Sounds like it has broken away at one end, possibly as a result of the shocker going "solid". Either way, you will probably need a new shock.
Corned
East Midlands
2005 S211 E320CDI Avantgarde
It's a 210 after all, so rust could well be the villain here, if a mounting has broken free due to corrosion?
Pathfinder
Gourock
Are there top mount bearings on this model ?
