Fob batteries
DAVE HULL KR
Hull
200 CDI 2006 55 plate saloon
Hi guys, just bought new batteries for my FOB, Whats the best way to fit them?
it's a 3 button fob from a 55 plate class.
Fairly fast and the correct way round.
DAVE HULL KR
DAVE HULL KR
Hull
:confused: the correct way? that's what i was hoping someone would help me with,
Remove the metal key and look into the side of the hole, and you will see a grey piece inside, press this with the key blade and at the same time put you finger nail between the top and the case and it will pull out when the grey catch is pressed in, the top slides out with the batteries
DAVE HULL KR
DAVE HULL KR
Hull
Thanks Malcolm :D
rf065
Grossbritannien
And once seperated, don't touch the grey plastic bit, it has a spring behind it & can travel quite far when it pops out! :eek:
Russ
Russ
I wonder where all these things that can pop out go too :confused:
I think the Beastie Boys summed that up nicely in their song "Intergalactic"
