Foot brake light staying on
scamm
help please loosing the will to live
after investigating a water leak in the passenger footwell on my ML270 2000
we found a relay burnt out called out auto electrician replace the relay run new cable to the join behind the speedo. re-fitted the dash and speedo only to find the the park brake light stays on when the footbrake is released when you drive this annoying buzzer keeps bleeping to tell me that the footbrake is on. put the car in neutral and it rolls freely any advice would be greatly appreciated
First pull the parking brake up with your hand to see if it goes out
star
Reading
Smart + others :)
check the switch is not displaced or the wires have become disconnected.
scamm
where would i find the switch when we released the the lever there was only a cable. should there be a wire? on the release handle sorry if i am asking stupid questions
star
Reading
Smart + others :)
Just above the pedal on the ali casting.
scamm
fixed it
star your are a star. the switch was not in its housing thanks for pointing me in the right direction:D
star
Reading
Smart + others :)
