Footbrake creaky
MSG2004
Kent
MB C Class 180k Se Auto Avtg Saloon.
Hi, i posted this before but no joy, the brake pedal creaks on the release, sometimes it's more noticeable than others and my wife can now hear it!
Intiall a few weeks back it was internitent and now almost a regular happening. The sound appears to be coming from under the dash
Try spraying the mechanism with one of the PTFE -silicon lubricants, they are clean and lasting.
Malcolm
M
MSG2004
Kent
thanks, but spray which bits and what is ptfe and where do i get it from?
M
MSG2004
Kent
btw - i did try the wd40, no luck
Tool shops etc, I even think that Halfords sell it., just spray as close as you can to the moving parts, its clean and safe.
malcolm
carabind
Lancashire
e class
which bits - Right near top of the brake pedal, it will be anchored to a horizontal shaft which allows it to pivot (or go up/down). You're looking for where the shaft goes through the pedal (probably a couple of bushes)
There's probably a spring attached to it which is worth a squirt
M
MSG2004
Kent
Thank you both!
I will update when i've tried it, possibly a week or 2 or on Monday when I'm working from home :D
