Frequent buzzing sound from W124
Waft
Cambridgeshire
1993 E220 Sportline Coupe
Hi!
On my 93 W124 E220 Coupe,I have an a frequent humming/buzzing sound coming from the rear.I notice this mainly upon start up.
I have run her onto the warning light on the fuel gauge many a time.I did recently change the fuel filter with an OEM one,and also the pipe from the tank to the filter which sheared at the union.
My concerns are over the difficulty of changing the in-tank filter,if this has one.I think these cars have an one there which is high pressure.Also the Bosch coily shaped one next to the filter.Is this right?
I'm kind of excited if the external one is knackered,as I could fit an Bosch 044 one as I did to my Audi 200 Turbo.Held a good steady,and higher constant pressure.The job on the in-tank pump on that car left me stoned and confused for the next few hours.....maaaan! :rolleyes::shock:
TIA
Steve:D
huey
Nottinghamshire
W203 cdi 2004 Estate
Hi, if it is most noticed on start up then yes it is the fuel pump, I don't think your car has an in tank filter, although someone will correct me if I'm wrong:D Just a thought You did say that you sheered a union, is the union leaking as it may make the pump work more?
You are correct the fuel pump is next to the filter . Hope this helps
Waft
Waft
Cambridgeshire
Hi Mark!
Hey thanks for that.
I hope there is just the one pump.
I did replace that hose mate.It was the alloy which they clamp/bond to the hose.It had failed,and I had probably twisted the hose upon loosening the fuel filter in all honesty.
Looking forward to someone posting up how many pumps I have!:D
Really can't be doing with getting stoned in the boot again.Funny on the day,mass headache the next day.Just say no!:p
robparker
Taunton
You definately only have the 1 pump under the car by the filter
Waft
Waft
Cambridgeshire
Back of the net!
Awesome,thanks Rob!:D
Did you fit the in line filter the right way round, the arrow indicates the direction of the flow and it often points towards the rear
wireman
lancashire
There is a tank strainer at least on the US model and my diesel, it is screwed into the tank from beneath at the centre, the pipe to the pump comes from it. A large rubber seal/grommet covers up the strainers nut.
If you do have a go at the strainer make sure the tank is empty before you take the thing out, a severely chocked strainer will hold a gallon or two of petrol back and this will gladly fall out as the strainer is removed.
You should remove the rubber seal and hold the strainer whilst the pipe union is unscrewed, the strainer might undo before the pipe if you don't and that makes a big mess if there is any fuel in the tank.
Don't go there if you don't need to.
One symptom of a choked strainer is that the "reserve" warning may only give a few miles warning and when refilling from empty (running out) it only takes 55-60 litres, it should swallow 70. I got 2 miles warning and ran out entering Tescos forecourt 20 yards from a pump, uphill and not a soul helped me push it.
