Ouch! that hurts.they don't need to be aware of it,
they just need online dealer kit and it will show them it has an update, do all 4 door modules !!!
quite remarkable all the same,
FR & FL
2214421832 have
2214424132 need from 06.40 (AKA 2006 week 40)
RL & RR
2214422132 have
2214424232 need from 06.40
you could do the front SAM and the Central gateway (which if you have a rear camera, that module will then need that flashing too, or it will come on driving forward and turn off going backwards !!!) these first too, will give the car enhanced diagnostic capability. It will then inform them to flash the Rear SAM. Which will then break things so I'd be reticent to do that one...
The Rear SAM needs 2214422600 from 2007 that came out after the front update. But some wise guy at Mercedes has set things up to flash it with a 2009 version 2219024903 from a facelift car and it doesn't talk to the Telematics correctly afterwards. And oddly having just re coded mine Mercedes just realise they'd forgotten in that update to correctly configure the rear blind
my tale of woe
Sept 2014 telematics updated at main dealer - all works no faults
Nov 2015 DAB retrofitted and added to data card at Merc toy specialist - all works no faults
Mar 2019 Updated rear SAM (as it said we needed to) - and roof OCP could be related, end up with a bug, still on the car to this day.
Source mute to allow you to hear Nav instructions is switched off after SCN software updates.
JAN 2020 attempt to change R SAM for one on 2007 software – garage messed up & damaged some wires & confused some modules – now have more bugs
JAN 2021 reflashed original R SAM, bugs go away & miraculously 13 years after build Mercedes finally remember to SCN the rear blind to the car (with updated coding)
VCD_Parameterisation Rear Blind - Hr initialisation: not initialised (initialised)
Still have the Source mute bug. So I think Mercedes have cost me £900 and two years trying, as they still need to turn back on the mute feature with SCN !!!
Facelift cars have this under Nav menus, older car's don't
Had mine done at an Indy in Penarth - cost £60Quite true!
Did the software fix your problem? @steve.linkHad mine done at an Indy in Penarth - cost £60
Home » South Wales Auto Ltd. | Penarth | Independent Mercedes-Benz & Smart Car Specialists
South Wales Auto Ltd. are South Wales' premier independent Mercedes Benz & Smart Car Specialists with over 25 years experience. | South Wales Auto Ltd. are South Wales' premier independent Mercedes Benz & Smart Car Specialists with over 25 years experience.www.walesauto.co.uk
That's near to where my daughter lives! I'll make an appointment when lockdown is over. Many thanks for the tip.Had mine done at an Indy in Penarth - cost £60
The garage is operating normally during lockdown - you just need to ring firstThat's near to where my daughter lives! I'll make an appointment when lockdown is over. Many thanks for the tip.
I have read this link with interest since I have a CLC with what appears to be a slow running and labouring passenger door window motor. Is this likely to be a mechanical issue. Reluctant to use until corrected since do not window to be stuck open. Thanks
Pleased to say I got the software updated and the problem went away! I used South Wales Auto Ltd in Penarth. Ten minutes job and cost £80+VAT.as STAR says, this is a normal problem,
a software update in 2007 fixed it. How dealerships got away without bothering is incredible. There's still about 10 a year crop up on a USA W221 forum, 3 or so from the UK with the same issue.
its 5 minutes per door plus the ago of booking it in and doing an invoice... Get all 4 doors checked / updated.
in your first post
221 442 1832 is the OLD original faulty software
221 442 4132 is the drivers door software you need
Took your advise and got the software updated. Many thanks for your valued help.Had mine done at an Indy in Penarth - cost £60
You are welcome!Took your advise and got the software updated. Many thanks for your valued help.
