front foglamp lenses
just bought a replacement front foglamp lens for my w210. if the weather holds, its this weekends job! is there any particular adhesive required to fit the lens to the lamp? if not, can anyone recommend a good one?
BlackC55
South coast
C43
It is clipped on with large metal clips. Use a screwdriver to prise them off.
pancholi
1996 SL 500 , 2003 CL55K, 2004 E320CDI
i have moisture collecting onb the fog lamp on my sl55 .. would this also be a matter of praising off...if so any sealent required?
Turn them on for a while when driving and they should clear
Xtractorfan
S class
Did a front end on a 210 a few weeks ago and cleaned up the fogs before fitting them, the clips holding the lens to the spotlamp have a little hole in them on the lamp side, if you insert a small terminal screwdriver into the hole and prise forward the clips will come off easy. dont be tempted to wipe the chromed reflector or you will ruin it, run it under a tap and blow dry..
pancholi
turned the fogs on for about 30 mins ...problem solved....
this morning...condensation back again...is it worth removing and re-sealing?
thanks
I will look it up later in the day
Xtractorfan
S class
Its also possible that the bulb holder may be loose or incorrectly fitted , the bulb and holder have to be turned 90deg. for the holder to seal..
pancholi
removed front sl55 grill mesh. 3 metal clips holding the glass in. one clip easy to remove. 2 potentially more difficult to remove/replace...any suggestions please
The lamps are removed by taking down the front half of the wheel arch liner, just remove the bottom screws and those ½ way up, you do not have to take them right off, then just unbolt the lamp
Hertfordshire Merx
A160
Make sure the seals for the bulb holders are not split, as the lamp cools i.e at night after they have been used on a journey the dense air coming in from an usealed part condenses.
