Front Pads/Discs
rafter_01
mercedes c220
Hi All,
New front pads/disc are due for my Mercedes car (C220 D 64 plate) and I got a parts quote for around £268 from stealers. Is this reasonable? Is it possible to purchase these parts elsewhere which are as good and a little cheaper?
JBell
Torquey
C350 CDi Estate (GAD Edition)
Grangemouth MB do good forum members discount and £5 delivery
ECP for Brembo / Pagid parts
R
rafter_01
mercedes c220
Will it be significantly cheaper? I find MB dealers very expensive. Maybe I can check Halfords?
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
£149 at euro car parts for brembo. Then there's labour , unless your DIY .
mioba
Nottingham and Köln
Dont be silly..... stick with OE Mercedes, lots of aftermarket have fitment issues. Ask a MB indy, they get discount and pass on the discount to the cutomer (usually) and fitting will be cheaper.
Been covered to death....
R
rafter_01
mercedes c220
with the other replies, i guess the parts will be cheap and not worth it?
I wouldn't get brakes for my push-bike from hellfrauds...:shock:
Gazwould
C250 CDI
Forget anything Pagid as ECP bought the OE division and cheaped out .
Brembo discs get my vote , and the genuine Mercedes brake pads will be Ferodo Eco Friction .
Screenshot_20210516-150400_Chrome.jpg 43b97c2b5cf2b59bd438a4e7ca2dde2e.plist.jpg Eco_Friction.jpg
R
rafter_01
mercedes c220
on the ECP there are two 'Brembo Brake Disc's options, £145.74 and £115.49, whats the difference?
JBell
Torquey
Probably vented and non vented. you need to check which ones you have
Gazwould
C250 CDI
Fronts will always be vented , you need to find out your disc diameter size .
R
rafter_01
mercedes c220
Looks the same size but the difference I see on the website is: one is Vented/Perforated and the other one is just Vented.
Whats the difference between the two?
EmilysDad
Bury Lancs
ML350
perforated are drilled too ....
mioba
Nottingham and Köln
Thanks, i could buy either? Whats the benefit of perforated discs?
heat dissipation.
Go for original pal. Too many questions is a tad indicative that you are very uncertain with all due respect.
