Front subframe bushes?
rockingsock888
Hi Folks, virgin posting for me. I have a 1998 vito travelliner which clunks when you take up the drive, a bit like an engine mount gone. I 've had a look at the montings and they seem OK. I have heard that the subframe mounts give a similar knock? Is this an easy job? I'm not too bad with the spanners.
mike
Mike, welcome to the forum.
Clonks will be drive /prop shaft splines and U/J's the sub frames are mounted in rubber bushes, and even when worn I do not think that they would clonk
R
rockingsock888
Cheers , thanks for that .i will have a closer look.
mike
