I asked the question because I have an A160 that clonks once if I pull away reasonably quickly and will also then clonk [once] on the overrun.
I can reproduce the noise with the car stationary by increasing the idle speed and then selecting D or R.
The clonk can be felt through the driver's side front engine mount [ the one attached to the cylinder head] and clearly heard on the subframe [ using a long screwdriver as a kind of stethoscope].
Changing the engine mount had no effect. I am now wondering about the front anti roll bar rubbers particularly as the anti roll bar clamp is situated directly below the engine mount where the clonk can be felt.
You lost your key ? Or maybe you need a spare!
Your vehicle imobilliser does not respond anymore?
WE CAN FIX THEM ALL !! Mobile !
Save Time and Increase Profits With us !
