Dec
what about taking a direct 12vdc feed to the pump to see if it fires up, this will give a better indication of where the fault is. if manual power feed starts the pump and water jets work, it leave a lot less possibilities and will take just a few mins to test
Do as Mark suggests, you need to establish if this is an electrical or a water tube problem.
Top up the washer tank wthh water
Put 12v to the pump, independently of the cars electrics, via a battery charger.
xxxxx
Observe if there is any water dripping from under the bonnet in case there might be a tube off somewhere
If the pump runs but no water at the jets then there must be a blockage or a kink in the tubes.
If the pump doesn’t run then it may be a stalk fault or something else.
I don’t know if the end of the stalk comes off on your car but I think it should, it’s a very tight fit, you need a very strong thumb grip, a piece of dry rubber over the end bit of the stalk will help.
Dec
