sixpack
- Mar 17, 2003
- Location
- Renfrew Scotland
- 2012 w212 220
Hi.
I have a problem with wear on the outer tread of the left front tyre. If I ask the advice of a tyre specialist, they always say check & adjust toe out/in. My thought is that if toe out/in is wrong, both tyres should wear on the outside or outside, depending on which direction the error is. Am I missing something here, or are these "experts" just trying to have an easy life. I have tried to measure the camber angles (find a totally level surface to park front wheels, check how far off vertical the wheel is, using a right angle & spirit level) This shows that the left wheel (the worn tyre side) has less neg. camber, about 2mm, compared with 4mm on the non wearing side. Is this significant? The Haynes book shows how to adjust camber, but I dont want do it without asking. Expert advice appreciated !
Peter
Peter
