Fuel average gone so bad after servicing
Aman1
C220d
Mercedes c220d 2019
Fuel average so bad this all happen after serving
Fuel filter , engine oil , air filter , oil filter
Everything changed . Fuel average was perfect before servicing . There’s no code on dash got it checked giving me like 14 mpg
A
Aman1
C220d
  • #2
Mercedes c220d 2019 57890 mileage
Everything changed . Fuel average was perfect before servicing . There’s no sings on dash . got it checked by local garage nothing came up on dignoes giving me like 14 mpg
A
Aman1
C220d
Recently serviced my c220d the mileage gone so worst its like giving me 14 mpg cunsuming fuel so much
AlanGunn
Anglesey
2013 C250 sport+ 2.1d
Are you getting 14mpg now.
Try it on a run.
malcolm E53 AMG
Welcome!
Check that the engine coolant system thermostat is working correctly if it’s stuck open the engine will overfuel
A
Aman1
C220d
Try it on a run.
Hi yeah it’s like 14 mpg there’s no sings on dash plus no code popes up on dignoes. The radiator fan on most of the time but the temperature is on 90 on the dash . The engine is bay is hot that you can’t even touch it .
A
Aman1
C220d
Welcome!
KennyN
Paisley
BMW 440i, Cayenne, ZX12r / ZRX11 / ZRX Monoshock
Its not doing a DPF regeneration is it ?
K
A
Aman1
C220d
Im
Not too sure tho . Wht should I do to the start stop doesn’t work plus the fun on even on a 3 mile trip
A
Aman1
C220d
But there’s no sign on dash plus car pick up is smooth
KennyN
Paisley
Dont think you get a sign on the dash during a regeneration , the signs are really poor MPG , slightly higher idle speed , very hot exhaust temperature.
Take the car for a decent run 20 mis or so , keep the revs up to facilitate the regen then rest your average consumption and see what it is after.
K
w204benz
2012 C200CDI AMG Sport
Unfortunately I have no idea what could cause such high fuel consumption, but as you mention 14mpg - is the fuel gauge dropping at an alarming rate or are you going off the computer reading?
On my (earlier) C class I have noticed that after a fuel consumption reset, it always starts at a default value until it has enough data to calculate the actual average consumption. And that value is 14mpg!
Perhaps your fuel consumption hasn't increased and the computer is showing the default value for some reason?
A
Aman1
C220d
K
Thankyou
AlanGunn
Anglesey
Was the fan running like that before the servicing.
Who did the work ?.
fabes
E400 Coupe
How about other (simple) things?
Stuff that should have been picked up on a service, but as you're running out of ideas....
Sticking brakes (calipers or foot / hand brake)?
Tyre pressures too low - unlikely but it may not be just one thing....
Have you reset the trip and been on a 30 mile trip where you can sustain at least 50 mph as you should see around 50 mpg?
Have you measured the actual fuel consumption via the pump and not just the on board trip in case that's giving you incorrect data (unlikely, but....)
Are you carrying a lot of dead weight in the car (or dead bodies in the boot!)
You've probably already gone through such a list, but just to go over the simple / simple to fix things
A
Aman1
C220d
  • #17
Thankyou
Fuel leak after changing the filter?
no there’s no leak I got it checked .
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Yeah it was . Local Garge
Take it back to the local garage, tell them what has happened.
Have you checked the fuel consumption full tank to full tank. Dont assume to computer is correct.
Bay Leaf
Stockport
SL 350 R231 2013
I'm inclined to agree with w204benz regarding the consumption re set, one of my cars does that after re connecting the battery.
Do you leave your air con switched on as the fan will run when the air con is operating.
