Fuel filter on a 220cdi 646 - prime it or crank it?
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
Hello all.
Has anyone changed the fuel filter on a 646? Does it really need priming?
I've done the filter on my diesel focus and my diesel bora, and never bothered priming it, just cranked the starter for about 15 seconds til it fills and starts.
I've looked on youtube and some videos show priming, some don't.
M80
Derbyshire
It will crank it through,
but I usually decant the diesel from the old filter to the new.
I always primed filters when I had diesels.
Uncle Benz
West Sussex
Mainly Mercedes
I always fill the new filter. Not only will you have to crank for an extended period before it will start, I always worry that either the starter motor will fail due to overheating or something else in the fuel system will be buggered up by drawing air. HP pump for example. Lack of lubrication can be terminal on those.
Yugguy
Yugguy
Rugby, UK
Cheers, not sure about putting diesel from dirty filter into new one though?
Uncle Benz
West Sussex
Mainly Mercedes
Probably ok as long as you pour it into the filter "in" pipe. Seems bonkers pre-dirtying a new filter though :)
Westheath
South London
If you don't have an electric fuel pump priming is beneficial.
I use a vacuum oil drainer on the fuel filter to HP pump pipe
and draw the fuel up from the tank filling the filter then pop the HP pipe back on.
Saves cranking especially on the S Type 2.7 engines such a pig to get started after a filter change.
Yugguy
Yugguy
Rugby, UK
That's a good idea, I hadn't thought of drawing from the tank.
ajlsl600
france
i always fill the filter , with fresh clean fuel then when it starts i keep it at high idle while it runs the fuel thru . some cars can be a bit of a B for this ,D4D for example,previously had to pressurise fuel tank, avoided when following above method
M80
Derbyshire
If it's taken from the 'out' of the old filter it's already filtered. It doesn't matter which pipe it's filled through on the new, but if prefered into the 'in' of that would filter it again.
Uncle Benz
West Sussex
Mainly Mercedes
Personally I'd avoid pouring anything into the "out" port of the new filter. Often the new filters come with a plug over the out port to prevent anything entering before you put the hose onto it. Although fuel drawn from the out port of the old filter is clean, the vessel or funnel used pose a risk of contamination. With appropriate care, probably safe, but for me - bad working practice.
Yugguy
Yugguy
Rugby, UK
Well that was pretty easy. Just used my hand vacuum pump to draw fuel through the new filter. Reckon I'll change it every 30k.
