dry run
- Aug 1, 2014
- Location
- Portsmouth
- Website
- kb-boatpark.co.uk
- CLS 350d AMG LIne Premium Plus
For some reason my fuel flap has decided it won't close and stay closed when you push it in. If I hold the flap closed and lock the car it will lock the flap closed, but will spring open again once unlocked. Also the flap feel loose at the hinge end, so don't know if the problem lies there. I can't see any way of removing/replacing the flap or inspecting for a failed component.
The rubber spring loaded button that pushes the flap open when pressed works fine, so its not that. It just seems that there is no mechanism for holding it closed (other than locking the car).
Does anyone know how to get at it? With the flap open, I can't see any screws or clips or anyway to remove it.
TIA
Steve
TIA
Steve
