Just found this forum and thought i'd ask to see if any1 has experienced the problem im having at the mo with my Mercedes.
Its a L reg (93) C180 esprit. MY Son changed the Fuel Pump and put a new filter on due to the car braking down Tues night on wifes way home from work, she got the the AA guy and he said the car is either over fueling or not getting enough fuel.
My Son changed the parts as the fule pump sounded worn as if the bearing was worn inside (rattling around).
Since this the car wont even start.
Theres no fuel getting up to the engine, my son removed the large rubber pipe that comes out the bottom of the fuel tank that goes straight to the fuel filter and the pipe is bone dry, he's blown it through with a air line and still nothing comes out thinkin it may of been blocked.
Is there a valve or anything inside tank?
Any help would be appreciated
