jibcl500
- Oct 22, 2005
- Age
- 56
- Location
- Cambridgeshire
- CL500,ML55,SLK280
Turn the key and let go, the car will crank on its own at this point, wait 10 seconds and crank on the key again the same way turn key and let go the car will crank on its own. Pump the accelerator pedal at the same time.
DONT CRANK THE CAR OVER CONTINUALLY AS SOMETHING MIGHT MELT!!.
You have air in the fuel lines and cranking the car is the only way to get it started, you should have filled the fuel filter with diesel before fitting it.
jib
jib
