Fuel pump cutting off prematurely
negotiator
e-class 220D
Just wondering if anyone has ever had the same filling diesel tank issue as myself. 2019 E220 model. I usually let the tank down to just less than 1/4 full, then buy my diesel. Almost always buy from the same filling station and have this issue happen on 3 occasions when i'm filling with just over half the tank filled the hose clicks as if the tank is full. I know it's far from it and keep filling but annoyingly it keeps clicking as if full. Any advice appreciated.
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
Nozzles can be sensitive to back flow of air. Use a different pump. Also make sure you have the nozzle pointing straight in and not angled.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
I have had the problem in the past with certain pumps where the fuel flow is quite fast. Just ease off on the trigger slightly. Thinking about it, I don’t recall a problem for the last couple of years now I’m back on petrol so perhaps it’s something to do with the way diesel foams as it goes in (exasperated by colder weather?).
Try a different pump/filling station some time.
A.J.
Norwich. UK
Thinking back, yes, that did used to be an issue with filling up with Diesel. I used to overcome it by just moving the nozzle inside the filler neck. That didn't solve the problem but it did ease it. Since having a petrol engine the problem hasn't arisen. I guess it's as Steve (Srdl) has said, petrol doesn't foam like diesel does and that is most probably where the problem lies. :)
I've had it recently with a Sainsbugs petrol pump - had to hold the lever only half on otherwise it would cut off. Back pressure sensor obviously too sensitive, I've noticed the Costco ones can be a bit sensitive as well.
rorywquin
North Yorkshire
An old B-Class.
It happens on my car, just move the nozzle out a bit.
mattkh
England
A160 W168 1999 1.6
If none of the above work, place the nozzle in such a way that the diesel runs along the neck of the tank.
N
negotiator
e-class 220D
Many thanks everyone for going to the trouble of answering. I will put the advice into practice going forward and come back to report.
