Having susspected a knackered fuel pump, (making knocking noise) just discovered a 2nd fuel pump near to it, do these both come off the same relay and run at the same time? Will they both need replacing?
Thanks to television for your reply, today I wired up pump nearest tank to battery to eliminate relay etc issues and found it would start but wouldnt run over 2000rpm, I then had a closer look at second pump and found a broken wire, rejoined it with a crimp connector, car now seems ok, just going to run it round block, bit worried about first pump sounding knackered, Ill probaly disconnect first pump and see if it runs on second only, they seem to be run in series
