Dean Fletcher
- Mar 24, 2018
- Location
- Penrith, Cumbria
- Mercedes S63 AMG
Yesterday I picked the car up from airport a mile down the road it starts jumping and stalled at the lights. I thought I’d stalled it so I set off again then the reg counter starts going up and down.
Read the codes it comes up with
The rail pressure sensor has a short circuit to battery?
Any one had a similar issue? Due to having kid in the back I pulled over called good old AA. He calls ahead of time and asks the issue; I tell him what codes I have read and the issue.
By the time he comes (30 minutes) iv had the car on and off and give it some revs and all seems to be normal again.
He scans it comes up with fuel rail pressure again. Then the engine light goes off.
I went for a test drive with him all seems normal. She said I can get it recovered but now all the values seem fine and can’t see any issues it was my choice. So I decided to go for it and travel up north.
Got through a busy M60 and onto M6 no problem all the way home no issues then soon as I stop outside the house and reverse into the parking place the car cuts out and I eventually get it into the parking place with higher revs.
I turned the car over last night sounds like a bag of spanner’s.
So……. The scanner is pointing at rail pressure sensor short circuit to battery but also but also power consumption of component y74 (pressure regulator valve) and component y94 ( quality control valve) is flashing red. Y74 at 728mA and Y94 at 812mA.
Today I’ll be looking wiring for all these components, connections and fuses.
I originally thought a bad fuel filter because it’s been 2 to 3 years since I changed it roughly 7000 miles. Iv got one on order now.
Any other pointers?
Any other pointers?
