Garage Rebuild
00slk
00slk
Cambridgeshire UK
  • #441
once you put a roof on, "isn't it dark in here"
It sure will be, 1 window and 1 glass door, didn't want to push our luck with the planning as it is already borderline with height and size for a domestic car garage.
My electrician mate is phoning me today with what I'll need in the lighting department.
00slk
00slk
Cambridgeshire UK
  • #442
00slk
00slk
Cambridgeshire UK
  • #443
If it had a full 1st floor it would be bigger than my late parent's 3 bed semi (as was the 26' x 20' garage I had built at our old house!).
A first floor is possible Chris, except it'll be in the way for the lorry and car lift ;)
Jimbo1959
Ayrshire
VW Scirocco. The Quattro, E350 CDi Blue Efficiency Sport Coupe, now both gone
eman
Walsall
21 EQC 400 Premium Plus
Umm failure on the tower build :rolleyes:;)
00slk
00slk
Cambridgeshire UK
  • #447
Slow progress again as things are getting back to normal and tradesmen are extremely busy.
Roofer will be back to finish off the gables when he gets a chance. :( (We really need the scaffolding taken down so the drive can be concreted!)
Guttering fitted though.
The electrician will be here next Wednesday and all the electrical bits ordered.
Garage doors ordered and should be here within the next 2 weeks, so I have been painting the inside blocks, first coat so far, I think I should have bought the smoother block finish as these blocks take a lot of paint and filling around the stones leaves it looking a bit lacking :rolleyes:
This morning I gave the beams above the doors and coat of black Hammerite :)
V6Matty
Newark, Nottinghamshire
Really fluffy roller is just about idea for this, oh and as it’s not external, water down the paint by about 1/5th, may take two coats but the finish will be so much better long term
Naraic
2005 CL500.
Buy a cheap airless sprayer.
Jim2
Yes, nonetheless, the finished product is starting to appear. Will be a fine job.
eman
Walsall
At the start of your project it was suggested fitting a car charger while the ground was out and earthing dilemmas. Well save your money as now spiking for your earth is no longer necessary as a good few chargers now come with everything built in so you can just earth straight to your house pme. So just fit one in the future if needed and save your pennies.
00slk
00slk
Cambridgeshire UK
  • #453
I started with a medium roller and found it was taking far too long, so I purchased a really fluffy masonry roller and it speed through the work :D
Might try the thinning process next Matt ;)
00slk
00slk
Cambridgeshire UK
  • #454
I did think of borrowing my neighbours compressor and spraying the walls but changed my mind when he said he had a telescopic pole for a roller brush :rolleyes:
00slk
00slk
Cambridgeshire UK
  • #455
I think the EV scene will be totally different in a few years......When an all EV will self charge while on the move with an auxiliary motor that runs on water. The fuel companies will no longer survive...........
Cheers Jim, there's a little at the end of the tunnel.......Just the light seems a long way away or the tunnel seems a long one. I am thinking it will be all done within 2 months :eek:
00slk
00slk
Cambridgeshire UK
  • #456
Not too bad Matt, a little bit of thinning sure helped the paint splash into the crevices.......And over me :D
Certainly speed up the process too. Good call ;)
V6Matty
Yeah that is one of the downsides, but as it’s already watered down it makes showering it off yourself easier ;)
As it dries you’ll notice how much it contracts showing off all the unpainted crevices in the blocks.... :(
Don‘t bother asking how I know...:(
00slk
00slk
Cambridgeshire UK
  • #459
Yep, thanks for highlighting my workmanship Blobcat :rolleyes: :p
00slk
00slk
Cambridgeshire UK
  • #460
Some further progress today as the electrician came and started fitting the lights and plug sockets, back tomorrow to fit the security lights and switches and to connect up the the consumer unit :)
Still waiting for the roofer to finish off the trim so the Scaffold can come down.
The doors should be fitted next week.
www.W140.co.uk&www.r129.co
