It should cost around £1800 to £2500 Try the GreenFuel web sitew you should get a quote on line. I had a 2001 3.0 A6 with gas for 4 years a dammed good car. You can hardly tell the difference and would recomend it. And welcom to the Forum.
wish i hadn't taken your advice.....no offence but five month down the line and at the moment the system is running on petrol. my only hope is that they will get it put right but........
What system did they install ?
That's pretty tough. My experience with a Prinz system has been much better. One broken wire to an injector and annual maintenance is the sum of my visits to the installers in 50,000 miles/5 years.
The money saving has to make it worth persevering if you can.
are you saying you have a ml320 4x4? because now i would like to find if there are any other ml320's out there with a brc system fitted. maybe better to start another thread.
