Gear box oil Capacity as of 08-08-05
Status
Not open for further replies.
722.329/341/342/343/344/351/352/357/359/361/363/367/368/369/371.
From initial fill 7.3 litres..... for fluid change 6.2 litres.
Shell Donax TA D-21666,21774.....Castrol TQD 22256.......BP Autran MBX
_________________________________________________________________
722.350/353/354/355/356/358/362/364/365/366/370.
From initial fill 8.6 litres.... for fluid change 7.7 litres.
772.500/501/502/503/504/505/506/507/508/509/510.
for new box 7.3 litres for oil change 6.2 litres.
Oil type
722.600/601/604/605/606/607/608/609/611/614/616/617/618/629/634/639/660/661/662/664/665/666//661/662/664/665/689/695/699/996.
for new box 7.5 litres (+0.5)
MB 236.10 ATF A001 989 2303...MB 236.10 001 989 2103..........
Shell ATF 3403-M 115
772.372/380/382/384/385/394/396/397/398/399.
new box 7.3 litres. Change 6.2 litres. Fluid type
772.331 8.6 from new. Fluid type
772.400/403/411/414/420/421/423/424/425/426/427/428/431/434/441/443.
From new 6.6 litres Change 5.5 litres. Fluid type
Shell Donax TA D-21666,21774.....Castrol TQD 22256....BP Autran MBX
772.408/409/412/413/415/417/418/433/435/437/438/440.
from new 7.1 litres.... Change 6.0 litres. Luid Type
772.800/810...................................................
When refilling 5.7 litres....................................
When refilling and converter 6.0 litres................
When refilling converter and cooling 6.5 litres.....
For fluid change without converter 4 litres.......
For fluid change with draining the converter 6.0 litres.
Fluid type CVT transmission oil type ATF 28-CVT, A001 989 46 03
All of the above transmision fluids are recomended by MB, This is for the UK,there are other fluids for different countries.
Malcolm
Sticky and locked.
If you wish to discuss this thread pls post replies here
Status
www.W140.co.uk&www.r129.co
