Gear selector light W124
Mercedes 190E
Walsall
stores.ebay.co.uk
2013 C220 CDI, 2004 A140 Classic SE (Parents!)
Just a quick one. The gearbox selector light in my W124 doesnt work-how do I get to the bulb to replace it?
Thanks !
roadhog
Sunny Norfolk
W124 300D x2, C124 300
Remove the trim around it (screwed at aft end, then lift out out aft end first) and you'll find a bulb underneath the forward left corner of the gear change assy.
Mercedes 190E
Mercedes 190E
Walsall
stores.ebay.co.uk
Sorry if I'm being a bit thick, but I can't see a screw to undo. Is it the whole wood panel that has to come off, or just the selector ? (I really dont want to break anything!)
Thanks.
roadhog
Sunny Norfolk
You need to remove the wood trim of the centre console around the gear shift. The bit where your window switches are.
Look under the carpet behind it (I'm guessing you haven't got the covered stowage, just an open tray) and you'll see the screw(s). Can't remember if there's one or two.
Unscrew, lift the rear up and unhook the front from under the ashtray.
The black plastic trim immediately around the gear selector is glued onto the wood on mine, not sure if that's a previous bodge by someone or if you can remove yours first to get some clearance.
It's a lot more simple to do than to explain. :)
Mercedes 190E
Mercedes 190E
Walsall
stores.ebay.co.uk
If only all jobs were that easy! Went to my local Merc dealer who gave me the bulb for free (Much to my surprise!) Fitted in 3 mins ! :D
