hi i just done mine today not for the first time as i have had other mercedes in the past all w124 a 300te & now a e200 as its a older car i do all my own work to service the box i ran the front up on ramps & removed the auto box sump plug & drained the fluid then did the same with the torque converter when all the fluid was drained i removed the sump pan from the gearbox & i removed the fillter only three screws hold it in place i fitted a new one then i poped the sump and sump plug & torque converter plug back on i then added 5ltr atf fluid & started the car with my foot on the brake at idle select 2nd then 3rd drive & R all for 10 secs to work the oil round the box i then drove for 12 miles to warm up the fluid then i checked the fluid .i now have smooth gear changes & at the right time
WE HAVE NOW MOVED: 8 Hazel Road, Woolston, SO19 7GB Service, Repairs and remapping service Any queries, please do not hesitate to contactEmail@mbsofsouthampton.co.ukor alternatively you can phone Colin or Dave on 02380 445820, out of hours numbers are 07787913313 or 07907631681.
