Gearbox oil
Graeme 1978
South Shields
E220 2012 2.1
Hi all does anyone know if a can change the oil and filter myself or is it a gearbox specialist job.
Am just curious thanks.
It's a 2.1 automatic on a 2012 plate E220 cdi w212.
Thanks Graeme
Kodyeml270cdi03
Ml 270 cdi 2003
Easy to do mate just take the trans pan off on the bottom of the transmission catch all the oil that comes out so you know how much to put back in an then you just pull the filter out an replace it with a new one
Mr Greedy
Leicestershire
E350/2011/OM642 265bhp
It's an involved job the first time you do it, but you can do it yourself. There are a lot of things to get right.
Sump pan bolts can snap whilst doing this, so you need to make sure you can recover from that where ever your doing it.
Car needs to be totally level. Oil has to be at correct temperature to measure the level.
The cost of this from a decent independent specialist can be as low as around the £200 region. Ive just paid something very close to that for my W212.
Good independents will be able to source the oil and genuine parts very competitively.
For the £80 saving I could make doing it myself, I just left it to the experts (not main dealer).
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
Thanks Graeme
Yes not only is it possible, but quite a lot of MB owners do it themselves, and there are plenty of "How To" posts here on the forum. . Having said that, you will need at least rudimentary mechanical skills... like everything else, there are tips and tricks on what to do...If you have any doubts about your ability, get a professional to do it for you. Its for sure not as simple as changing the engine oil and filter. Each of the two main MB transmissions, 722.6 and the 722.9 have diffdrent change methods. Check You Tube " MB Automatic Transmission Fluid Change" and you will see plenty of vids on how to do it. Do your research well before youn start.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Let us know how you get on ... :)
He probably has the fill from below 7g box , you have the 5g with a dipstick tube (I would guess )
G
Graeme 1978
South Shields
E220 2012 2.1
Thanks 4 all the replys
A won't be doing it just yet a was just curious if it was possible to do or do a need to get saving to get the job done.
Thank you
Graeme
onefortheroad
uk.
Thank you
Graeme
£200 at most places. Not worth getting it wrong tbh.
mioba
Nottingham and Köln
Everythings possible with the right knowledge and tools.
Lots of vids on youtube.
Jim2
Its worth bearing in mind that you get what you pay for......You can see a lot of transmision oil change kits online, showing filter, gasket and 5 /6 litrs of ATF. This will only be enough for a "quickie" change, transmission only ( approx 4.5-5 Ltrs) meaning that the sump is drained, removed, filter replaced, new gasket fitted, sump replaced and refilled with ATF. This does not include Torque Converter ( 3.5/4 Ltrs), oil radiator and transfer pipes ( 2 ltrs ) and a further 2 ltrs for flushing,which a complete change and flush requires. This is for the 722.6 transmission. I used 12 ltres when I changed my 722.6. I've since changed the car for a slightly newer one, ( 2014 220 CDI, 722.9 trans) and while it still has some time / miles to go before the next ATF change, I've already got the complete change kit..including 20 Ltrs of fluid ( special offer ) £130, so I'll change it in the next few weeks, weather permitting. Changing the 722.9 trans is a slightly different procedure in that you can access and drain the TC via a drain plug, same as the trans sump, but you will still have to flush out the cooler radiator and pipes, and the refill process is different too, as the fluid has to be pumped back up into the trans( the 722.6 can be refilled via the dipstick, so its much simpler )
G
Graeme 1978
South Shields
E220 2012 2.1
Next question is how do a no what box is in my car.
Sent from my SM-A520F using Tapatalk
Jim2
Sure it is, the right knowledge and a mechanical aptitude being the key as you can generally purchase the tools. But I've seen some right bloopers on YouTube as well,,,,so a bit of care is needed.
Jim2
How many gears are in it? I'd say its the 722.9 trans, But to be absolutely sure, open the driver side front door, and on the piller, under the lock catch, there is a sticker. Under the DAIMLER AG, you will see a series of letters and Nrs, starting with WDD. This is that particular cars VIN ( Vehicle Identity Number) To deciper this, Google ( where would we be without it?? ) MB VIN Decoder, and select one from the list. Download the decoder, enter your VIN in it, and hey presto...everything you want to know about that particular build MB will be shown, inc engine and transmission type and code. Do that, and then we will know " Above and Beyond a reasonable doubt" what is in your Merc. You will find this data very usefull in future too, if youn ever need part's etc.
onefortheroad
uk.
AFAIK if its got stop start its 7g+ , no stop start its 7g .
The s class and e class with v6 engines saw 7g+ from 2010.
Jim2
Yes, mine has the stop start so 7g+ I assume. To drain the TC in the stop start trans, you have to remove the auxilary pump from the transmission ( this is an electric pump which keeps the fluid in circulation while the engine is stopped during stop start operation ) Then you have to manually turn the engine until the drain plug on the TC becomes visible, and it can ge drained. The 722.6 does not have a drainplug on the TC, and so must be flushed out via the oil cooler pipes. I think that the 7G trans may have this feature too ( IE TC Drain plug) but I'm not 100% sure about it.
G
Graeme 1978
South Shields
E220 2012 2.1
  • #18
Thanks 4 the advice it seems a lot of faf just to change the oil al have a look on that VIN decoder thanks.
Graeme
Jim2
Graeme
Compared to changing the oil in a manual transmission , yes it is but the autotrans is unbelievably more complex than the manual one, and has a hell of a lot more moving parts and electronics, The VIN decoder will give you a whole lot of usefull info about your car. Ive downloaded it on to my phone, and it comes in very handy when I'm in the garage ordering part etc.
G
Graeme 1978
South Shields
E220 2012 2.1
  • #20
So just had a look at the vin decoder and this is what it says.
AMG speedshift MCT 7-speed sport transmission is that any help
