Gearbox Safe Mode & ABS light on
Bruce Mansell
I have a W202 1997 C230 K 5 speed electronic auto box. I have not used the car for 4 weeks and now it sticks in limp (safe) mode and the abs light is on. Could it be low voltage in battery? car starts normally on key.
Also how do i reset the box using the throttle & ignition as I have lost the instructions.
Bruce
I would give the car a run the best that you can,,do check that the battery is giving over 12 volts, then try again
was it jump started? have you checked the fuses.
B
Bruce Mansell
w202 gearbox problem & ABS light on
No It was not jump started I have not checked any fuses. Can you tell me what to check and where to find them.
Do you know how to reset the box from safe mode?
