Gearbox stuck on Park
rabla
Hi all,
I have a Mercedes CLK 320 year 2000, the gearbox is stuck on park, I can not change from park, it is stuck there. The car turns on and I can release the parking brake, but I can not change gear from Park.
Any recommendations on what to do in such case, will apperciated .
Thank you in advance
Kind Regards
Cole@MBS
www.mbssouthampton.co.uk
Welcome Rabla
Sounds like you need to replace the brake light switch!!!
Hello and welcome to the forum, the brake light switch can cause this, but I cannot guarantee that that is the fault.
They only cost £10 and are easy to fit
Iain the gadget
Edenbridge, Kent
W208 230CLK W163 ML270cdi
You can release this by passing a pencil into the small aperture next to position D (small flap) to engage the gears
R
rabla
Thank you
Thank you, I appreciate your help, it is most likely this, I will inform you otherwise.
Thank you for the help : :)
Cheers
