Gears not selecting
Barrie Sheppard
E320 2003
Hi. Just bought mercedes e320 2003. Fine for 2 weeks then lots of snow and rain esp warning and car wont select any gears. All warming codes reset thinking of taking battery off. Any ideas. HELP
Rappey69
hants
c220 w204 amg sport
As an answer to your question I could say low atf, gearbox electro plate, gearbox control unit, gear level control unit etc..
Each one of the above can cause gear issues, but each displays certain symptoms.
A better explanation of the fault might help, but ultimately the answer will be to get diagnosed on star.
malcolm E53 AMG
If the battery is old or not holding voltage the ancillaries including gearbox will start to shut down so my first port of call would be to check the battery and replace if necessary
What did you use to reset codes and what codes were there before you reset them?
B
Barrie Sheppard
E320 2003
Sorry don' know much about cars 3 error codes were on 0716 , 0730 and 0230 cleared with obd2 still no change. Removed battery for couple of hrs no change. Battery measured 11.5v oil was 6.0l but on a slight bank. I'l try on straight tomorrow thanks
P0730 is the clue - the other 26 relate to fuel.
That said it's also probably only part of the story.
But going on that code alone possible causes are as previously mentioned.
Check fluid level and if still getting it after fluid verified as correct it could be stuck valve (dirt contamination usually), failed electroplate or failed oil pump.
Pray it's low oil.
B
Barrie Sheppard
E320 2003
Pray it's low oil.
B
Barrie Sheppard
E320 2003
Thanks what level should the oil be at cant seem to find it on the net
You need to buy a dipstick for the box. It's marked on the dipstick.
You'll also need a new lock tab for the dipstick hole. You can't leave the dipstick in permanently.
B
Barrie Sheppard
E320 2003
Thanks seems to start no bother getting 13.8v when running what voltage should I be getting thank you going to check a few things now
Linuus
crawley
w210 wagon
Are u seeing those 13.8v of the AC control options position 24? Or are u taking the reading with a multimeter. Mind that the voltage on the AC special menu position 24 will shows 13.0/13.8v but if u use a multimeter ether using the from pin to jump start of by touching the back battery u should get a reading of 14.5v this way u know the battery is receiving charge from the alternator.
Had last month similar issue. With battery low, but end up having to change the starter. So even with battery low i was able to start the car (after replacing the starter)
jp williams
Wirral & Axarqia,Spain
2002 E class 2.2 cdi auto estate, Lexus GS 450h
If bought from a Dealer, then get him to fix it f.o.c.
