Genuine amg mumtispoke? How to tell?
Iainc350
C350 2010 3.0 v6
I am currently after some amg multispoke wheels, have been offered some any ideas how I know if they are proper amg ones? Or replicas?
Has sent some photos over
Iainc350
Iainc350
C350 2010 3.0 v6
  • #2
These photos also
Replicas tend not to have AMG cast into them (problematic if AMG come after them!)
John Laidlaw
Wirral
Land Rover Discovery 4
Genuine
But are they for your C350?
Check the ETs and/or check ‘will they fit’ as I think those are off a W222
Iainc350
Iainc350
C350 2010 3.0 v6
Genuine
I sent the photos to local tyre fitter.
He said they should fit.
I hope so as hoping to purchase them
Tomorrow
John Laidlaw
Wirral
Tomorrow
Did you have more photos with the ETs stamped on them all?
I'm not so sure they will fit. Your rims are 45 and 54mm offset front and rear. Those are 38 so will sit 7mm closer to the wheel arch at the front and a massive 16mm closer to the arch at the rear.
They'll also make the ride terrible.
Iainc350
Iainc350
C350 2010 3.0 v6
I'm glad you guys know what your on about saved me buying something that will not fit.
Thanks for all your advice.
Keep your eyes peeled for some multispoke wheels for my c350
John Laidlaw
Wirral
You’re welcome - worth knowing what you have first and what you can interchange to before looking around, that way you’re prepared to jump when you spot something
AMGeed
Poole, Dorset
S204 C180K
One thing worth mentioning is that the multispoke genuine AMG wheels are especially prone to cracking.
If you really want that design I would look at aftermarket wheels on eBay with a very similar ET to the ones you currently use.
Look for Front ET 45, Rear ET54. The lower the number from these figures, the closer (in mm) the wheel will be toward the arch.
Any ET bigger will make the wheel closer to the hub/suspension.
If you spot something and aren't sure, get the details here and someone will advise. Don't trust your tyre fitter:D
Iainc350
Iainc350
C350 2010 3.0 v6
  • #17
Other photo sent don't know what this is?
Iainc350
Iainc350
C350 2010 3.0 v6
  • #18
Could spacers be used?
www.W140.co.uk&www.r129.co
