Get some engine rattles C-Class (w203)
bitonw
West Midlands, UK
www.bit4net.com
Because I had to replace the glow plugs I found this;
While removing the engine covers I saw 2 broken rubber buffers (A6110940385). They hole the top of the air cleaner. I also saw an hose with some damage since it rubs against the engine.
To remove the engine covers you need a torx T30 screw driver to remove the 6 bolds. Then you can lift the engine covers off.
As the pictures shows you can see the broken rubber buffers. They cost only a couple £ and are easy to replace. Also have a look at the hose (see picture) what (in my case) gets damaged by hitting the hot engine. I rerouted this hose to not hitting the engine any more.
jberks
So it affects the 220 too. I had a lot of vibration on the air filter box on my 270 when I got it. They replaced the 'rubber mountings' and it was fine again. I guess it was the same part.
bitonw
bitonw
West Midlands, UK
www.bit4net.com
Yes, it might be the same parts. The guy of the Mercedes Benz parts department told me that there are also 2 rubber mountings on the under site of the air cleaner who like to brake too. But the top once goos more often.
