ghost in the fan...
Gavin450slc
Manchester
www.manchesterfetish.com
I have a 1980 450slc and the fan motor was squeeeeeeeling like a stuck pig, so I opened up the cover and give it a squirt of WD40.
Anyways.
Now I am happily driving along (guzzling ocean liners worth of fuel on every trip to the shops) when the fan just switches itself on!
- the switch in the car seems fine and normally will turn it on through all four settings normally - however, the fan just kicks in at full blast every now and again, regardless of setting...
do I need ghostbusters?
Ta.
Gavin.
G
Gavin450slc
Manchester
I'll tell you what....
I must be the first to have this problem - as this forum is usually the most forthcoming I have ever encountered - so in the interests of fairness, once I fix this bugger, I will let y'all know what it was!
Gavin.
LNM
Birkenhead.
I'm about to go aoutside and take the fan out of my 190 to see why its dead. Had the ole squealing myself before it packed up altogether.
Neophyte
Sqeal and then die?
Damn , mine's (on a 190e) squeaking a fair bit. did you try and lubricate it or just put up with it? i wonder if the mechanicals are the same?
jberks
If it was an E ....
Gavin,
I dont know about the 450. Mine (2000 E class admittedly) has a fan regulator. On mine, the regulator started squealing exactly like a stuck bearing and after a while the fan speed would vary eratically from off to full without touching the switch. The reg has a live and neutral feed together with a feed from the switch to tell it how fast to run the fan (roughly 0-8v when I checked it). If yours has one, and its duff, you will get the squeal and its quite capable of switching on the fan on its own.
