glove box broke
D
dave thomas
hi i have a clk 270 cdi 53 plate the glove compartment only closes with a good slam i have seen this complaint advertised and a reply from televison member can you advise me on fault
D
dave thomas
  • #2
please help glove box on clk 270 cdi only closes with a good slam
I will send you the details and welcome to the forum :D:D
You should have 2 Emails from me
reuben
Mercedes CLK W209 270 cdi
Hi! I have exactly the same problem - the glove box closes with a good slam but otherwise it doesnt. Please could you send me the advice too?
Strangely it is also a CLK 270 cdi 53 plate just like the other guy!
Thanks :D
Thanks :D
It is as MB service center says,,that is all you have to do.
reuben
Not sure exactly which screws you mean - Ive got a CD changer in there - there are 4 torx screws on the inside of the door of the glove compartment, and there are two adjustable rubber buffers to the left and right above the CD changer. There are no visible screws on the actual catches...
I can send you the details of what all of the screws do
reuben
Great thanks for all the help!
Cheers :D
Both sent to you
MB Service Centre
Mansfield
www.mbservicecentremansfield.co.uk
A210 E320
hi, sorry forgot to say if you have a cd player! if you look in the centre on the roof of glove box at the front,you will see one screw, remove this then you can pull the cd changer out, then you will see the 2 screws that i was on about, then you can do as i wrote in the other post.
thanks
rob
neutron
broken glovebox
Hi, my problem is with a 1990 300sl front glovebox.
The top catch is not operating/ closing. Any ideas?
Is this the spectacle compartment or the box on the left
I have sent some details,,it is cable controlled and this could be the problem
reuben
Hmm I cannot find that screw. I have attached a picture of the glove box - it has a cd storage unit in it as well - I think I can see a screw above that but I'm not sure how to remove the CD storage unit.
Suggestions?
Suggestions?
I have the details that I can E mail to you
reuben
Great - email is <now been removed!>
2 pages sent :D
