glove box latch
pancholi
1996 SL 500 , 2003 CL55K, 2004 E320CDI
on my sl55 . the glove box door stays closed even with the open button pressed..
this happens on an erratic basis.
i have put WD40 into the mechanism , with no improvment...
any sugestions please. and instructions on dismantling if needed ..thanks
Hertfordshire Merx
A160
I'm presuming you have a 129 or 230 SL. If its the glovebox in the dash then it sounds like the cable has disconnected of the lock has developed a fault. If you take the end panel off of the dash you should gain access to get your hand in and manipulate the cable to get it open if thats the fault. Obviously if it is then remove the glovebox and refit it properly/replace any broken parts.
pancholi
pancholi
it is an 2003 sl55(230).
it does open sometimes (about 20%) but the remaining 80% of the time i have to jar it open...
I miss read the box in question, the catch in the top is adjustable, if it opens easily all the time when the car is unlocked, if it is only after the car has been locked, then it is the cable as Mercedes herts said
pancholi
pancholi
its a pain to open at any time!!!....weather the car is locked or unlocked
Then adjust the catch in the top.
I think that I have a how to paper on this
pancholi
pancholi
i can feel that there are two small screw on the roof of the glove compartment, which i believe corespond with the latch....
sorry what do you mean adjust. .....forward/backward position?...cable?...mechanism?
thanks
You can slide that catch around wait till I find the details
Hertfordshire Merx
A160
There is a bowden cable inside a black conduit attached to the lock with a white adjuster which rotates to adjust it. Its right handed thread.
I have the adjust paper for you.
As I will be sending you a few papers, why not activate the Email address in your user CP and save changes once you have done that
I have sent you the paper, but Email not in your user CP,,did you save the changes at the bottom
jfgw
Hi Malcolm,
Sorry to hijack this post, but would you mind forwarding that paper to me too please? I have the same issue and just wanted to know which screws to undo to remove the side panel of the glovebox to be able to reach the adjuster wheel.
Thanks very much,
James
Hello and welcome,,I need an Email address please, and you can edit it out when you get the info
jfgw
No worries Malcolm, I fixed it - thanks for the info in the thread :D
