A couple of thoughts...
Hi Mick,
If it's blowing with such force, then there is a reason hidden somewhere.
If you need it fixed for your test, then I would try all 6 glow-plugs and a resolder. However, as was mentioned above, a £60 control box (recon? second hand?) could cure it, but if there is a rogue plug that measures OK, then you will short out the link in the "new" control box too.
If it's not required for the test, then I would ignore it. The car will start OK on the remaining plugs, as I have read here in the past.
HTH
Jon
Hi Mick,
HTH
Jon
