Glow Plugs (again)
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
I have located the glow plug relay (e300td) it looks like a sealed unit, how do I get access to the fuse (s) to check?
F
FIBAMAN
TYNESIDE
Nick,
thanks for the reply. car is 98 E300TD I am sure I have 1 or 2 plugs off.
Someone earllier suggested FUSES (plural) I thought maybe it could be a split load system (1 fuse for 3 plugs) so worth a check first. I have located the relay which was described as having fuses but it looks like a sealed box to me are the fuse(s) elsewhere
Parrot of Doom
Manchester
The face holding the connectors slides out of the box. You may have to crack it open with a large flat bladed screwdriver or two. If you break the plastic, just tape it back together and seal the gaps with grease. The 6 fuses are inside, and easy to find. Large shiny metal fork-like things. If they're gone, you'll see.
F
FIBAMAN
TYNESIDE
Thanks Parrot. Very useful info.:smile:
