Madanglian
If so, does it foul the rear silencer on your exhaust?
I can answer yes to all these questions, although some bright spark has at some point inserted a piece of rubber in between bracket and silencer in order to prevent what would otherwise be an absolute ****** racket.
Trouble is, it's lifted up and stressed the rear section of exhaust in a way which it wasn't designed for and the pipe has broken off the inlet of the silencer.
The bracketry itself is a piece of 2 inch square section tube running longitudinally between two plates, one of which is bolted onto the body just in front of the rear bumper, the other plate bolted on about 15-18 inches nearer the front of the car.
Is this a standard Merc towing bracket or a home-made (or after market) affair?
Also having read another thread about cheapo exhausts, are the "BQ" ones from German/Swedish/French any good?
Hope I'm not breaking Forum rules by naming names.......
Thanx
Thanx
