Grr Exhaust bolts
cocothecat
Cardiff, South Wales
Focus, CLK 230, 911, Spitfire MK II
Ok so today I was planning on cleaning and spraying my exhaust tip but for the lift of me I can not undo the bolt that holds it to the exhaust. I have the correct bit attached to my screwdriver but It will not budge.
Anyone got some ideas
s and k autos
middx
320 SL 300 E 124 SHAPE
get the tip into the screw hit it with hammer then try ti un screw it use wd40 as well
C
cocothecat
gave that ago and still wount move :( my hands are on fire form the force im using on it
brandwooddixon
Wolverhampton
S63 Coupe 2014
If you have a gas torch / blow lamp. Perhaps application of heat and then a spray with WD40 or similar will shock it enough to free it.
Otherwise spray every day for a week with pentrating oil.
C
cocothecat
I'm going to get a high torque drill from my parents later and give that ago.
Cheers for the heat idea i'll try that if it fails
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
Be very careful with gas torches blowlamps etc under the car SAFETY FIRST
