JSeaman
Step 1 - Use a small flatblade screwdriver to ease the airbag plastic cover off
Step 2 - With a posidrive screwdriver remove the large screw behind the cover
Step 3 - Remove the 3 smaller philips screws holding the chrome trim in place for the door shut then pull the trim away
Step 4 - Now remove the single screw that holds the plastic cover for the door latch mechanism then slide the trim off
