Guys.. what is that? (M111.960)
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Peter Kevin, Mar 24, 2020.
  1. OP
    Peter Kevin
    Peter Kevin Member
    18
    Mar 24, 2020
    Indonesia
    Your Mercedes:
    1996 W124 E220
    I never had the urge to turn on the heater because here in Indonesia the weather outside is usually around 30ish C on daylight so AC is always necessary.
  2. OP
    Peter Kevin
    Peter Kevin Member
    18
    Mar 24, 2020
    Indonesia
    Your Mercedes:
    1996 W124 E220
    I still cant get that rubber thing off the pipe it sticks there really good it just wont come off. I tried gouging it but its elastic material just make it impossible it just sticks right back to its place... I really need help:D
  3. EmilysDad
    EmilysDad Senior Member
    8,688
    2,322
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    Ah! That'd explain it! :D:D:D
    Peter Kevin and Jim2 like this.
  4. Jim2
    Jim2 Senior Member
    1,008
    682
    Jan 18, 2018
    Your Mercedes:
    2010 Eclass w212 2.1 CDI
    What ever it is, it's not natural. If it's a "Rubbery" substance, see if you can screw a wood work drill bit into it by hand, and keep a vacuum cleaner going beside it while you are at it. That should get it out.
    Peter Kevin likes this.
  5. LostKiwi
    LostKiwi Senior Member
    23,282
    12,528
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    If that's the heater circuit and you never use it just leave it?
    Jim2, Peter Kevin and Blobcat like this.
  6. star
    star Forum Supporter Authorised Forum Supporter
    5,398
    864
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    It maybe that the heater is stuck on hot, so a previous owner blocked it given where you live. If you never need heat, leave alone.
    Jim2 and Peter Kevin like this.
  7. daibevan
    daibevan Senior Member
    1,164
    721
    Sep 29, 2015
    Plymouth
    Your Mercedes:
    W203 C200 Kompressor Elegance SE 2006
    +1
  8. 00slk
    00slk Senior Member
    3,786
    2,169
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    2002 SL55 AMG, 2005 SL500 2009 SLK350
    On most cars the heater unit is situated inside and up behind the dash board, if the heater matrix leaks it drips water in side the heater casing and eventually fills and over flows onto the carpet, hence wet carpet ;)
  9. mioba
    mioba Senior Member
    1,279
    271
    Feb 19, 2006
    Nottingham
    Your Mercedes:
    W124/1994/E200, W220/2004/S320CDI, W205/2016/C200, W447/2017/3.0 CDI
    Regardless, engine wil still need cooling
  10. OP
    Peter Kevin
    Peter Kevin Member
    18
    Mar 24, 2020
    Indonesia
    Your Mercedes:
    1996 W124 E220
    Since most people here telling me to leave it alone.. I guess Im just gonna leave it alone.. but is it not going to damage my engine in the long run?
  11. OP
    Peter Kevin
    Peter Kevin Member
    18
    Mar 24, 2020
    Indonesia
    Your Mercedes:
    1996 W124 E220
    Thanks, will definetely try it. I like my machine clean and originale:D
  12. LostKiwi
    23,282
    12,528
    Aug 25, 2006
    Your Mercedes:
    Before you do that run some water into the rubber hose it attaches to. See if water come out the radiator (with the cap off). Also check you don't get wet carpets.
  13. OP
    Peter Kevin
    Peter Kevin Member
    18
    Mar 24, 2020
    Indonesia
    Your Mercedes:
    1996 W124 E220
    Guys, I got another problem.. the car was running completely fine literally minutes ago, I took it for drive after completing my coolant flush, went to refuel, and it suddenly hesitate and began to sound like an old V8.. :D
    its shaking like crazy and act like the engine is about to die, I popped the hood, I see nothing unusual besides the machine is shaking like theres no tomorrow and went to the back and see white smoke, not too thick, but a lot.
    And now Im at the side of the street, raining, and clueless.. is this somethig I can fix or I should just tow this thing somewhere
    Heres the video
  14. mattkh
    mattkh Senior Member
    1,547
    29
    Aug 2, 2006
    England
    Your Mercedes:
    W168 1999 1.6
    Sorry to hear that.
    Did the shaking start after you put some fuel in it.?
    On your test drive, were you keeping an eye on the temperature needle?
    To be on the safe side, it is advisable to get it towed to wherever you want.
  15. OP
    Peter Kevin
    Peter Kevin Member
    18
    Mar 24, 2020
    Indonesia
    Your Mercedes:
    1996 W124 E220
    No, it actually started before I got to the gas station, but maybe it was my fuel, because it is running very low
  16. OP
    Peter Kevin
    Peter Kevin Member
    18
    Mar 24, 2020
    Indonesia
    Your Mercedes:
    1996 W124 E220
    I guess I found the problem:( 20200327_210259.jpg 20200327_210259.jpg 20200327_210307.jpg 20200327_210307.jpg
  17. LostKiwi
    23,282
    12,528
    Aug 25, 2006
    Your Mercedes:
    That looks like lot of water in the oil.
    Pop outcall the spark plugs and compare them. You should find one that's considerably cleaner than the rest.
  18. OP
    Peter Kevin
    Peter Kevin Member
    18
    Mar 24, 2020
    Indonesia
    Your Mercedes:
    1996 W124 E220
    Yeah the water in the reservoir all empty I guess it all went into the oil:(
  19. mioba
    mioba Senior Member
    1,279
    271
    Feb 19, 2006
    Nottingham
    Your Mercedes:
    could it not be then that the thing blocking the cooling pipe is something like radweld and the fact you just flushed the coolant and found this problem means you dislodged some of that radweld.
  20. mattkh
    1,547
    29
    Aug 2, 2006
    England
    Your Mercedes:
    W168 1999 1.6
    Sometimes after a coolant flush you can get air locks in the pipes. After running the engine the water level goes down as the air gets out.
Share This Page
