Handbrake pedal return spring
Trev1964
Lydney
CLS 250 cdi estate 2013
My daughters CLC has developed a minor issue.
The footbrake pedal is not returning to its normal rear position anymore and the warning light and buzzer are coming on as a result.
If she lifts it with her foot slightly, all is well.
Suspect the return spring has snapped on the pedal.
Anyone have a link to somewhere that can supply the spring?
Anyone know if its a standard part across the range?
Thanks.
DMK/Happy
SE / Coupe / 2003 / C 220/CDI/A
Thanks.
Had the same problem,was advised here on MBO to lift the rear seat,see the round inspection cover in the middle there,remove, lube and grease the linkage and cables exposed underneath , activate the brake and see if it frees.Worked for me.
There is a knurled ratchet above the foot brake pedal , try spraying some lube on that first
Trev1964
Trev1964
Lydney
Thanks guys. She's visiting in a couple of weeks. So I'll take a peek when she's here.
