harmonic balancers recall in US... whatever that is
blassberg
Warwickshire
alt.autos.mercedes reports
Just got a letter in the mail today announcing that Mercedes admitted
that the harmonic balancers in 1998-2001 cars were flawed.
They offered to replace the flawed devices at no cost under the terms
of the recall.
There was a reimbursement form attached -- so if you had a failure,
and had it fixed, you could submit the repair claim to Mercedes.
If you're in this group of owners ---
the recall campaign is 2005-020003
toll free information is -800-FOR-MERCEDES (1-800-367-6372)
The Editor
In the Middle
I THINK the harmonic balancers are summink to do with the camshafts (to make them quiet)... But I'm not sure. In fact I'm never really sure of anything !!
996jimbo
C43 estate
Snot the bit that goes around the back of your neck so's the harmonica's near your mouth if you're playing a guitar is it?
pascal
near Dublin
sl320/1999/3.2
I have heard of some of these engine balancers (twin counterbalancer shafts)(I presume that is what you mean) failing, on some US sites. That was over a year ago. These balancers make up for the less than pefect angle/configuration of the VEE engines
I do not think it was too widespread. It affects the M112 v6 engines. The M113 V8 does not have a balancer.
The Editor
In the Middle
I seem to remember they rotate in opposite directions so as to counter the inertia induced - thus 'counter balancer shafts' - had them on an old Bitsumishi many years ago.
Come to think of it they might even be a Japanese invention (or something they stole and made half the size and more efficient)
996jimbo
C43 estate
I think that 'counter balancing' is not the same as 'contra rotating', both or either of which you may want from a balancer shaft. Counter balancing would smooth the engine (counter balances the heavy bit of the crank which is trying to counter balance the piston going up & down), contra rotating then cancels out the inertia of the rotating crank which affects steering (in a for/aft engine). Not sure if it has to be contra rotating - I'm no expert...
pascal
near Dublin
sl320/1999/3.2
I could not find that site alt.merce.......... , Blasburg.
What is the address?
blassberg
blassberg
Warwickshire
newsgroup for your newsreader, Passcull
alt.auto.mercedes
I use Mozilla Thunderbird off news server news.individual.net
pascal
near Dublin
sl320/1999/3.2
Ah, see
Haven't used a newsgroups since I had MSDOS (pre windows).
Never even activated it on my settings, although my server does have the facility.
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
Harmonic balancers are the big round wheel that is keyed to the front of the CRANKSHAFT and drives the fan belts to the accessories. It usually has the ignition timing marks on it. The balance shafts etc you are referring to are totally different articles. The harmonic balancers are usually two concentric pieces of steel with a rubber type compound inserted between the two rings. Any failures are usually due to the rubber bit failing and the balancer coming apart with somewhat disastrous effect to all parts near and attached.
blassberg
blassberg
Warwickshire
So the sintered crankshaft pulley?
blassberg
blassberg
Warwickshire
blassberg said:
have asked them to translate from US to UK
Top marks Oigle
Response was
No, It's a harmonic balancer, Usually a big metal disc with a rubber collar that mounts on the outside of the Engine at the end of the Crank shaft.
