DeltaD
- Nov 21, 2019
- Location
- South West France
- CLS 320 CDI AMG
If so which did you purchase for the job. Thanks.
Obviously not!If so which did you purchase for the job. Thanks.
It doesn't seem like it ....Obviously not!
never mind.It doesn't seem like it ....
Additional wiring won't connect with light sensors. The standard lights will operate relays/controllers to dim or switch off DRLs when they switch onCan imagine it will take a lot of effort and wiring to the switches and light sensors so on and so forth.
drl relay for sale | eBay
Find great deals on eBay for drl relay. Shop with confidence.www.ebay.co.uk
????Then a need for relays too right?
Yes ..... as per the eBay link I posted.Then I assume there would be a need for relays if the OP was to fit DRL's
Brabus made them... I have them on my SmartIf I recall correctly, there was an option with the AMG style bumpers to fit twin fog lamps, one of which is then a DRL.
Afraid to say I wouldn’t have a clue on who did the kit though
Television fitted some to one of his R230’s and had a few issue, LED strips were still quite new at the timeI believe the you mean W219 CLS as the 119 is a Vito van ??
When i had my 219 i contemplated fitting them , the options at that time were :
Prise open the light unit and install some kind of LED strip
Remove the lower fog light and adapt some form of LED to fit in the space but loose the cornering function.
Cut a strip out of the bumper and house something LED in the created space.
All of the above were discounted due to cost , availability , reliability of Chinese LED products.
LED DRL`s are on all the time and have minimal current draw so dont think relays or wiring them into sensors would be required , pick up a spare 12+ switched supply from the fusebox and that should be it.
So to answer your ?
No
K
ThanksIf I recall correctly, there was an option with the AMG style bumpers to fit twin fog lamps, one of which is then a DRL.
Many thanksIdeally they want to dim or extinguish when 'night' lights are in use. As well as if close indicators are operating.
On a Vito I installed LED dual lamps into the indicators. Bonded into the lamp holder the DRL feed was drilled through the back.
I picked up the feed from a spare fuse in the fuse box and that was extinguished via a relay powered from the sidelight.
I think it was something like this kit I adapted
2x 60 LED Dual-Color Switchback Daytime Running DRL Turn Signal Light Bulb Kit | eBay
Find many great new & used options and get the best deals for 2x 60 LED Dual-Color Switchback Daytime Running DRL Turn Signal Light Bulb Kit at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
