Head lights stay on r230
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by 00slk, Feb 14, 2020.
  1. 00slk
    00slk Senior Member
    3,405
    1,777
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    2002 SL55 AMG, 2005 SL500 2009 SLK350
    Driving to the hospital today I noticed the headlight light to say the lights are on was on. Gee that's a mouthful o_O
    Then I noticed that the headlight switch was off :confused: Turned the lights switch on and then off, the light stayed on and when I got close to the car in front noticed my lights shining in there back doors.
    When it was time to come home it was dark, the Missus collected the car from the car park and told me, 'yes your lights wont go out unless you turn the car off'. o_O Very bizarre :confused: So she turned the lights on manually just in case they went out. The main switch??
  2. SL55 Mark
    SL55 Mark Senior Member
    2,559
    300
    Oct 1, 2012
    South
    Your Mercedes:
    2004 SL55 AMG
    Give it a wiggle. Try some contact cleaner on the switch.
    00slk likes this.
  3. OP
    00slk
    00slk Senior Member
    3,405
    1,777
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    I'm gona be a bisy boy once back on deck :D Oh but fosrt need sleep, general anaesthetic and 5 hours sleep last night not a good mix for inteligence...........or spelling :oops: ..............
  4. EmilysDad
    EmilysDad Senior Member
    8,316
    2,027
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    there was a setting on my R Class dash cluster to set the headlights to be on all the time .... a kind of DRL setting for countries that required them .... maybe yours has too :confused:
    00slk likes this.
  5. mercmancdi
    mercmancdi Senior Member
    3,244
    685
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    What yr is it , isn’t it all cars from 2011 got drls. And also as said earlier loads of models have a constant on for lights in menu settings.
  6. dionysus
    dionysus Active Member
    33
    16
    Jan 5, 2016
    North Yorkshire
    Your Mercedes:
    SL500/2004/5.0
    My SL has the option to have lights on all the time in the computer settings.
    00slk likes this.
  7. OP
    00slk
    00slk Senior Member
    3,405
    1,777
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    Over the winter my switch is usually left on auto, but no setting on the dash or switch to leave on all the time, or not that I have found :D
    2002, probably not as advanced as I would like it to be :) I haven't searched for the menu setting for a while, the only time I did this was when I was waiting for someone and had a play, I managed to restrict my speed setting to 140 and when it was dynoed it wouldn't managed its top speed :rolleyes: I have reset the speed to 150 now :D
    Looks like I am going to have a look as soon as I am up and running again, but surely it shouldn't self set if it wasn't manually set? :shock:
    Conor likes this.
  8. Conor
    Conor Senior Member
    1,095
    414
    Jan 22, 2019
    London, UK
    Your Mercedes:
    Can't help with the problem.. But get well soon and wish you a full and speedy recovery :)
  9. OP
    00slk
    00slk Senior Member
    3,405
    1,777
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    Thank you Conor, 6 weeks recovery time though I can get about one one foot :)
    Conor likes this.
Share This Page
