Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
Having two alloy wheels refurbished ( due to leaking seal … corroded rim) on 2002 A Class - circa 3 days turnaround time. Whilst waiting, I noticed the heads of the wheelbolts were really well rusted. See below.
So I sanded them smooth, derusted, left overnight, primed in the morning 2 coats with 30 min wait time, then left overnight to dry then base metalic coat in afternoon 2 light coats 30 min interval i.e. double recomended interval time , left overnight.
Clear lacquered this morning , left 40mins ( tin said 15 mins ) then another coat of clear.
Note I tried to keep the flats as thin a coat of paint as possible, but heavy coats on the domed end of bolts .
Looks like this:-
OK its a semi crap finish, with a few dust specs , but way better than raw heavy rust.
How long would I have to leave it to dry, before it would take the 12 point Socket up to 110 Nm.?
Or will it always crush the paint off the corners of the flats? Note this is not 2K hard paint, just Halford acrylic paint.
I am pretty sure it would need galvanising or powder-coat as a minimum to properly withstand the torque wrench.
My thoughts are: to leave the supporting box 48 hours on top of a double radiator for the clear coat to harden.
Then have a go, ( note need to put the spare an the second wheel asap to get that refurbished) I am expecting the socket to damage the corners of the head, but hopefully leave the domed top of the head unmarked and the skirts of the flange unmarked …. Ergo general overall effect no longer super rusty or am I dreaming?.
what they looked like before
Note new bolts are circa £7each so thats £28 x 4 = £112 ! IMO Not worth it for the Dear Old “shopping trolley“.
The stems and threads having been oiled are not rusty at all.
The stems look OK to me. The slight paint overlap on the bevel will no doubt shear off with 110 Nm .
I am just trying to avoid a really mashed up gloopy look.
So if the general consensus was to leave it 4 days I could. Question is would it make any difference?
Looks like this:-
