Heated Mirrors
C
creepy coupe
Can someone please advise me how they work, the handbook states "automatic" so are they on all the time, or below a set temperature?
The cars a 1998 SLK 230
Many thanks
roadhog
Sunny Norfolk
W124 300D x2, C124 300
On any of my cars they come on when you select the heated rear screen.
C
creepy coupe
The same here, all except for a TT I owned and they were on all the time.
matthewm1965
Durham
1999 W220 S500L, Toyota Supra Mkiv, 1970 Triumph GT6
Not sure about the Mercedes system as I have not seen it working yet ! But when I had the Rover 800, they were on all the time, summer & winter. The ones on the Vectra came on with the heated rear window.
C
creepy coupe
Someone has suggested they come on when you use the screen demist function?
Some cars it comes on with the demist, others (later ones) when it drops below 5'C. Today I had the first frost on mine, however as my screen is very clean inside and out it didn't take very long at all for the demister to clear it and the mirrors.
C
creepy coupe
Thanks for that Bobcat, I was hoping for a reply like that :D
The AIR temp and start up circuits come into this, and all CAN BUS driven. The mirror heater is controlled from the door control ECU and is switched on and off by the outside air temp sensor, they are switched on at temps below 5c and switched off at 10c and above. If the widow is opened,then the mirror is switched off, to save energy.
They also come on automatically with the heated rear window
Dec
Ireland.
W202
The best way of knowing under what conditions the come on is by touching the mirror with the back of your fingers, you will feel the heat in the glass after about 30 seconds.
Dec
whitenemesis
CLS55 AMG '05
As Malcolm says (on mine at least) mirrors come on with the ignition at temps below 5c and stay on to prevent misting up in foggy weather etc..
C
creepy coupe
I diid have the rear screen on for about 10 mins last night, but didn't notice the glass feeling any warmer
I'll try some other senarios tonight.
Dec
Ireland.
W202
I have never been able to feel the heat in the back window while the heater is on, I think it is a much slower affair, you can really only tell if it is working when it clears the mist, the mirror on the other hand becomes quite warm to the touch.
Dec
Dec
Purely on mass Dec, the mirror is so small compared to the back window plus the mirror is floating, and the window is attached to the body of the card
whitenemesis
CLS55 AMG '05
The heater must still raise the temp of the glass above the dew point to drive off the moisture.
A colleague had a rear window explode due to a fault in the heater where it didn't auto switch off
Lisa Jayne
Ashford, Kent
1998 SLK 230K & 2003 ML270 CDI Inspiration
Gave my wing mirrors a touchy feely when I got home and they were both definately warm, outside temp 14.5, no rear screen demister on, so I would think that they are on all the time ;)
No they are not on all the time, they work as in my post 8 they may feel warm but that is only heat that has worked its way up into the housing
Lisa Jayne
Ashford, Kent
Well my passenger side one was almost hot to the touch so just guessed that the heating was on sorry :roll:
Maybe it is stuck on or something,,,we have had this question up many times and it has never been answered exactly,,this morning I spent an hour checking on how they work,,and it is the same for all cars.
I will look, at the 170 specifiably later today
whitenemesis
CLS55 AMG '05
I must correct myself. The temperature I quote was incorrect, should be switched on at temp below 15c and off at temp above 19c :Oops::Oops:
OK so we do have differences in our cars with the on and off temp,,as I said mine are on at 5c and of at 10c,,the main thing is that we now know how they are turned on and off, even if the temps vary,, just shows Peter how much colder your car is than mine:D
I am pleased you found it in the end:D
