Heater motor noisy
mercmadjim
Cornwall
SLK230k
The heater motor on my SLK is noisy, could someone please tell me where it is located? as I want to remove it and clean and lubricate it.
Thanks.
mercmadjim
mercmadjim
Cornwall
SLK230k
Is that in behind the dashboard Malcolm?
Yes sir couple of screws and its out and the connector, it best to not try and touch the fan, I use a thin screw driver dipped in oil and drop it onto the shaft near the bearings,,I do it several times spinning it as you go
mercmadjim
mercmadjim
Cornwall
SLK230k
Thank you Malcolm, I will have a look tomorrow, do I have to remove the dash, or glovebox at all? or is it under the dash?
I can look to see if there is a DIY on this for you,,give me a few mins
mercmadjim
mercmadjim
Cornwall
SLK230k
Thank you Malcolm, you are a star, I look forward to meeting you on the 31st!!
I have sent you 2 paper on the complete job
