goosergus
Hi all. I have never quite known exactly how my van blower system works. Mayhaps someone can enlighten me.
Sprinter 208d lwb no air con.
I have three controls
1. The temprature control has varying temprature guide from hot through to not quite so hot! What i mean is a red line that is thicker at top of range and thinner at bottom of range but no instance of blue (cold) just varying degrees of hot. Even in the winter and at the lowest heat setting i get hot air.
2 My blower switch has 1,2,3, and 4 options for strentgh of blow but if you push the control in a red light on it illuminates and the air blows stronger. Whats that about? Is it simply a confusing 5 setting?
3. The direction control. This has all the usual options; up down recirculate etc but the option to let air blow through straight from the main inlet still blows hot air even if it is minus 1 outside. I realise this problem and number one are related but just letting you have the full picture.
