heater problem
petermalone
just bought a 04 E270 but heater does not work , blows but not hot
i have felt the pipes and only warm and they dont seem to have water in
HOW DO YOU BLEAD THE PIPES
:confused:
Xtractorfan
S class
What temp does the guage read when the car is fully warmed up, If the header tank is showing correct levels when the car is standing then the problem is more likely to a sticking thermostat or duovalves...
No duo valves in this one, well I cant see them, no pump either
5pares
Suffolk
E320cdi
I suspect it will be the valves that sit under the master cylinder at fault.
Possible but they always fail in the hot mode, ie no voltage going to them
