- Banned
- #1
190D 2.0 litre
Have a problem with my heater when you turn the fan on after 30seconds the heater blows cold air. When you turn the fan off for 30 secs and then back on again the heater is warm then starts to go cold again. Water pump and thermostat are all OK
Head gasket OK not losing water temp gauge sits at 85deg I am trying to check the heater valve [picture below] can you tell me what control operates the valve as there doesn?t seem to any movement in it when you move the heater controls. When you move the valve manually it still makes no difference hope someone can help. Thanks in advance.
